-   -   Nonstop Flushing (http://www.diychatroom.com/f7/nonstop-flushing-164837/)
michaelson 11-26-2012 10:54 PM
Nonstop Flushing
One of the urinals in my restaurant's bathroom keeps flushing. I assume the valve must be stuck open. I've fixed tank toilets that continue to run (replacing the flap), but this doesn't have that.
Dare I attempt or should I call a plumber?
joecaption 11-26-2012 11:00 PM
See that flat head screw in the center of the fitting where it turns to go into the top of the urinal? Turn it in to shut off the water flow.
Since you did not include the make or model number here's some ideas where to find the parts list.
http://www.bing.com/images/search?q=...ures&FORM=IGRE
michaelson 11-26-2012 11:06 PM
It's a Zurn Aquaflush value; I think the model number is Z6003PL-WS1
TheEplumber 11-26-2012 11:31 PM
199 Attachment(s)
Turn the screw Joe references clockwise to turn off the water.
Now try to flush it a couple times to relieve the pressure. Now you can attempt to remove the top dome on the flush valve. They can be very stubborn. Once inside, you can pull the diaphragm and rinse it really well to remove any debris. Also, slowly turn on the water to allow it to overflow out of the body- this will help flush more debris out. Reassemble and try it. If you don't feel confident doing these steps or it doesn't cure it, or you can't get it apart, then yes, call a plumber
jnc401 11-27-2012 07:14 AM
Non stop flushing
First off, you must turn off your water when working on any type of flush valve. The relief valve may not be seating properly or the bypass orifice is clogged of foreign material. There also may be an invisible gelatinous film from over-treated water. Usually a flush valve repair kit for the specific model will alleviate the problem
michaelson 11-27-2012 08:36 AM
I got the valve apart, cleaned it out, and got it back together without leftover parts. That didn't fix the problem; after the first flush it continued running.
Should a new diaphragm fix it?
TheEplumber 11-27-2012 08:40 AM
199 Attachment(s)
yes it should
joecaption 11-27-2012 08:40 AM
It should, did you see any other parts thet look messed up?
michaelson 11-27-2012 02:53 PM
Nothing looks messed up... The cleaning didn't fix it and it didn't look dirty to begin with. I picked up a repair kit at a janitor supply store I use. After dinner I will put it in.
michaelson 11-27-2012 09:29 PM
I got it fixed with the repair kit!
TheEplumber 11-27-2012 10:20 PM
199 Attachment(s)
Feels good huh!
