Old 09-18-2012, 10:05 PM   #1
Non plumber condo owner in CA
After 12 years no noise, our pipes are singing. It can happen on any
fixture. Not real bad, just enough to notice. Same with our next door
neighbors who have a separate water service.
Plumber friends suggest prv, so I call the City Water Dept., they come out, and say you don't have a prv, because your main supply is only 55psi at the hose bib. Everyone is stumped as to what the cause is.
Tonyboysf is offline   Reply With Quote
Old 09-18-2012, 10:35 PM   #2
may be something stuck in main shutoff.....run water at a fixture go to main shut off and turn it off slowly..see if noise pitch changes or stops...
Old 09-18-2012, 10:37 PM   #3
Doing it myself
Alan's Avatar
Did you leave a hose bibb with a vacuum breaker in the on position with the hose charged?
That can cause it.
Journeyman Plumber
plumber (sole owner) does NOT have a worker's compansation edavt04@gmail.c Plumbing 4 03-15-2012 06:51 PM
New Condo Owner!! MisezDiana Introductions 0 09-29-2010 05:55 PM
Problem with Condo (boiler pipes) Video Included. BA! HVAC 2 01-15-2009 07:14 AM
I Called a Plumber, Now I really need Help! kswoot Plumbing 8 10-14-2008 08:57 PM
HELP! I'm NOT a plumber. And I don't play one on T.V.! kswoot Plumbing 20 10-02-2008 02:14 PM
