Non Metallic PEX Fittings - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-02-2012, 08:45 PM   #1
Non metallic PEX fittings
We construct aeration systems in wastewater applications where the pH can sometimes be corrosive to metal. I love PEX and have stretched it over 1/2" PVC being used as a nipple. But I would like to use legitimate PEX nipples if possible. Does anyone know if non-metallic PEX fittings exist.
SludgeHammer is offline   Reply With Quote
Old 02-02-2012, 09:20 PM   #2
Looks like Zurn makes a plastic fitting called PolyAlloy that's compatible with both the standard crimp rings & ss clamps. http://www.pexinfo.com/
VIPlumber is offline   Reply With Quote
The Following User Says Thank You to VIPlumber For This Useful Post:
plummen (02-02-2012)
Old 02-02-2012, 10:08 PM   #3
GC/Master Plumber/Mech
Rewards Points: 560
I think zurn has been a class action suit about their fittings.
I know my plumbing warehouse changed from zurn to someone else.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 02-02-2012, 10:30 PM   #4
It was Zurn fittings, but the brass ones, http://www.zurnclassaction.com/. Not sure about who else makes plastic ones for the OP's needs.
Old 02-02-2012, 10:33 PM   #5
Rewards Points: 636
viega still rules in pex
never used plastic fitting only bronze but they have them
http://www.viega.net/xchg/en-us/hs.xsl/5208.htm
jaydevries is offline   Reply With Quote
The Following User Says Thank You to jaydevries For This Useful Post:
ben's plumbing (02-02-2012)
Old 02-02-2012, 10:48 PM   #6
Rewards Points: 582
we use wirsbo pex with brass and polly fittings...have not had any problems expandable with rings...tools are expensive....
Old 02-02-2012, 10:50 PM   #7
You mean propress? They certainly are sweet, but not sure if the tool is available for rent to the diyers.
Old 02-03-2012, 10:00 PM   #8
Rewards Points: 636
no propress is for copper press. for pex is pureflow pexpress you can use there manual hand press or a propress gun with right pex press head
Old 02-04-2012, 06:49 AM   #9
Civil Engineer
Rewards Points: 4,938
Wirsbo Uponor makes two different types of fittings. There are the brass ones, which I have not been too happy with, and the polysulfone plastic fittings, which I think are great. As mentioned, Wirsbo is the only company using the expansion system with crimp rings, which requires a special tool which costs several hundred dollars to purchase.
Daniel Holzman is online now   Reply With Quote
The Following User Says Thank You to Daniel Holzman For This Useful Post:
ben's plumbing (02-04-2012)
PEX Brass Fittings Turning Inside Tubing After Cinch Clamped GeeJay Plumbing 1 03-01-2011 09:16 AM
PEX Brass Fittings Turning Inside Tubing After Cinch Clamped GeeJay Plumbing 1 03-01-2011 07:06 AM
New House + PEX + Plastic Fittings = ? GaryZ Plumbing 22 01-06-2011 08:47 AM
remove compound from brass fittings to unscrew fittings purpleheart Plumbing 3 05-08-2010 06:49 AM
Sharkbite brand PEX fittings at Home Depot rjniles Plumbing 1 03-16-2010 07:33 PM
