Non-freeze Hose Bib - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-25-2009, 07:34 AM   #1
Non-freeze hose bib
I have a non-freeze hose bib on a house that the owner left a hose connected to this past winter (and it was a cold one in here in the northeast!).
It is installed thru an 8" CMU wall parged on the outside and the basement is finished on the inside (1" air space, 2x4 wood studs and 1/2" drywall). When the hose bib is turned on it provides water just fine but the CMU basement wall gets wet all around the bib. I'm talking about an apparent leak within the CMU cores of the wall. No sign of leaking inside on the drywall. When the bib is shut off the CMU and parging eventually dry out.
What happened to this bib? The washer is is the bib shot? Why does it show signs of leaking when turned on but not in the off position? Is this something that can be fixed by removing the stem from the outside or am I looking at cutting the dry and doing the fix from the inside? I'm guessing that the bib cracked between the shutoff and the outside correct?
ettev is offline   Reply With Quote
Old 05-25-2009, 08:18 AM   #2
Rewards Points: 562
yes you are correct,take it off and solder it shut and reinstall,,,or buy a new one. Winter time hoses not allowed.
4just1don is offline   Reply With Quote
Old 05-25-2009, 12:45 PM   #3
You ask what happened. Water was left in the stem tube. The water froze, expanded, and split the stem tube. You can do as 4just1don suggests, pull the frost free and solder the split or replace it all together.
hayewe farm is offline   Reply With Quote
Old 05-25-2009, 01:15 PM   #4
Trying to repair a split tube will be difficult and time consuming. You need to purchase a new unit. Remove the old one first so you know the length as they come in assorted lengths.
Fast1, frost-free faucets must be able to drain when turned off. If not, they freeze and break.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Drain hose stuck on washing machine savingedmund Plumbing 3 05-10-2009 10:19 AM
Repairing Electric Central Vacuum Hose jogr Appliances 6 11-11-2008 12:59 PM
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 12:27 AM
replacing hose bibb leroyme Plumbing 23 04-16-2007 05:45 PM
Washing machine drain hose morrisp Plumbing 3 09-01-2006 07:24 PM
