Noisy Sump Pump Check Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-01-2010, 08:04 AM   #1
Noisy sump pump check valve
Had my sump pump replaced about 9 months ago. It works fine except that the check valve is annoyingly loud. The former pump that came with this house (6 years old) had a brass check valve that we could hear but was much less noisy than the plastic one the plumber installed. Is there a best solution to the noise? I have seen ads for a valve called the "silencer", has anyone tried this product?
I apologize if I am reawakening a thread from the past.
Deltav700
deltav700 is offline   Reply With Quote
Old 10-01-2010, 08:11 AM   #2
there is a silent swing check on the market. it has a second flap inside that hinges from the middle, eliminates the bang. Once I get some coffee in me i'll find you a link, or you can google silent swing check to see it
the_man is offline   Reply With Quote
Old 10-01-2010, 08:21 AM   #3
Chicago, IL
Michael Thomas's Avatar
Often, you can substantially reduce the "bang" when the valve closes by installing it in a horizontal position (you add elbows and a short length of horizontal pipe), check the manufacturer's installation instructions, most can be installed this way.
As an alternative, there are quieter (but not truly "silent") valves, for example GOOGLE "Silent Sewage Check Valve".
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Well Water, Fluctuating Water Pressure, and the Roller Coaster Pressure Gauge huuuss Plumbing 24 12-11-2011 09:03 PM
Loud sump check valve BlueBSH Plumbing 1 01-19-2010 04:14 PM
Sump Pump Design handy man88 Plumbing 2 10-04-2008 09:48 PM
Water Mystery - Sump Pump Set Right? robertr4836 General DIY Discussions 4 02-13-2008 02:32 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 09:36 AM
