Noisy Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-22-2011, 05:45 PM   #1
Noisy pipes
My water heater is in my attic above my bathrooms. AFTER running hot water for a while, like a shower, when I turn ON cold water I hear loud noise that sounds like the pipes in the attic are banging on the rafters. I've been up there to witness it thinking I need to strap them down but they are not moving. In fact they are supported with pieces of foam pipe insulation so it apparently isn't the pipes hitting on wood.
Any ideas?
Thanks,
Chris
Swampworks is offline   Reply With Quote
Old 01-24-2011, 07:48 PM   #2
Question
could be pvc around flashing
is this a ranch?
Check the fill valve in the toilet?
this sounds silly but you may have thermal expansion and it is pushing on the cold lines and making the fill valve vibrate.
when this happens lift the tank lid and move the float with your hand see if it goes away or gets worse. if it does replace the fill valve and put a thermal expansion tank in. this is my guess ive seen this before this is a pressure build up and it happens on the cold side so putting the expansion tank on the cold side will help if this is the problem.
please reply id like to see if you fixed it.
plumbbum0203 is offline   Reply With Quote
Old 01-24-2011, 08:43 PM   #3
Owner
LateralConcepts's Avatar
Sounds to me like the water heater is popping and crackling. Might be time to replace it. Especially if it's in an attic. Hard water, calcium, build up, excessive pressure, etc. could be causing your noises.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 01-25-2011, 04:36 PM   #4
This water heater is only about 6 years old. Could it really need replacement already?
Old 01-25-2011, 06:01 PM   #5
Owner
Maybe not replacement, but due for service if you haven't already. I would drain it to eliminate any sediment build-up
Lateral
(208) 818-8241
Combining vent pipes in the attic. a4aj Plumbing 5 02-04-2010 11:20 AM
Toilet Flushing Causes Noisy Cold Water Pipes mrduck10 Plumbing 3 02-03-2010 06:10 AM
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 09:03 PM
Noisy pipes that is getting worse and water pressure that is odd to say the least! RallenK Plumbing 2 10-14-2009 10:07 PM
noisy pipes duffers Plumbing 6 11-08-2007 01:16 PM
