Noisy Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-12-2012, 09:04 AM   #1
Noisy pipes
I have noisey pipes in my home, mostly when I flush the toilet. When I flush two of my toilet it makes a connecting sink faucet drip. When the noise start, if I turn on another faucet the noise will stop.
rodeothor is offline   Reply With Quote
Old 04-12-2012, 09:14 AM   #2
Rewards Points: 14,312
Things that can cause this.
Air in the lines.
If your on a well check the pressure in the pressure tank, there's a valve stem on the top of the tank. There should never be water coming out of that valve, if there is the bladder inside is shot.
Pressure set to high in the main line. Should not be higher then 60 PSI.
Old 04-12-2012, 09:56 AM   #3
noisey piprs
Air in the lines.
I have city water and how do I check the pressure and check if air is in the line?
Old 04-12-2012, 10:20 AM   #4
City can check the pressure for you for free or you can buy some fittings and a gauge and attach it to an outside faucet.
To get the air out of the lines I start at the incoming line and work my way to the end opening up all the faucets for a few min. one at a time.
Make sure to open up the relief valve on the hot water tank until water comes out. Do not forget all the outside faucets, and the tub.
Old 04-26-2012, 03:24 PM   #5
Which is the incoming line?
Old 04-26-2012, 06:17 PM   #6
Rewards Points: 516
Let the forum know:
When it started
If any plumbing mods took place around that time
Fully open all valves under sinks and toilets, lawn sprinklers etc hot and cold, as first trial.
diyorpay is offline   Reply With Quote
Old 04-26-2012, 06:23 PM   #7
Not positive but I think it started after a bathtub repair. It stopped but started back again.
Old 04-26-2012, 08:42 PM   #8
Rewards Points: 582
maybe if water was off for tub repair...when turned back on got dirt in lines that clogged in some fixtures????
Old 04-27-2012, 05:26 PM   #9
If something broke loose and got clogged, would that cause noise? I will try to remove the air from the lines by turning on one faucet at a time.
Old 04-27-2012, 08:17 PM   #10
Try changing ballcocks. They have parts that can cause chatter.
plumbbum0203 is offline   Reply With Quote
Tankless Water heater noisy pipes rawills5339 Plumbing 1 03-09-2011 06:06 PM
Noisy pipes Swampworks Plumbing 4 01-25-2011 06:01 PM
Toilet Flushing Causes Noisy Cold Water Pipes mrduck10 Plumbing 3 02-03-2010 06:10 AM
Noisy pipes that is getting worse and water pressure that is odd to say the least! RallenK Plumbing 2 10-14-2009 10:07 PM
noisy pipes duffers Plumbing 6 11-08-2007 01:16 PM
