Noisy Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-11-2007, 10:19 AM   #1
noisy pipes
I'm having a problem with my cold water pipes. Whenever i use a large faucet(bath/shower/ water sprinkler) i get a loud humming sound throughout the house. For example, while using the water sprinkler which is attached to the basement, I hear the noise out of my upstairs bathroom three flights up?
Any suggestions on how to fix this?
duffers is offline   Reply With Quote
Old 10-11-2007, 11:29 AM   #2
Does this occur while the water is running or just after the water is shut off?
redline is offline   Reply With Quote
Old 10-11-2007, 11:49 AM   #3
while the water is running. It is so loud it wakes my kids up!!!
The pipes are perfectly quiet when they are shut.
Old 10-11-2007, 01:45 PM   #4
Are these copper pipes or galvanized pipes?
Old 10-11-2007, 02:17 PM   #5
i know some of them are galvanized. It is probable it is a mix of both.
Old 10-11-2007, 09:31 PM   #6
Custom Cabinet Maker
check everywhere you have access and strap em tight. Sounds like vibration from flow with loose pipes
skymaster is offline   Reply With Quote
Old 11-08-2007, 01:16 PM   #7
actually the supply pipes are copper.
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 07:22 AM
Water Heater 1/2 inch pipes tke402 Plumbing 7 10-04-2008 11:19 AM
Installation of new pipes on Water main... NJE Plumbing 3 02-05-2007 12:06 PM
Is it normal to see green stuff on the supply pipes KUIPORNG Plumbing 2 06-30-2006 11:21 AM
noisy tap (really noisy!!) - help please Nikki Plumbing 2 04-23-2006 08:56 AM
