Old 07-01-2005, 05:16 PM   #16
Noisy Pipe
Originally Posted by Umby
Plumguy, I think I have an very similar problem to Sheepie. Every time my washer, shower, or the one toilet is activated, I get this sound from the location of my hotwater heater. I have heard water hammer before in other houses as the toilets shut off, but this only happens when things are turned *on*. It sounds like somebody dumped a box of softball-sized rocks on a driveway! And it's not just one bam, but goes for a full second or two. Where should I start looking? thanks
I would start with checking you're water pressure and the temp of you're hot water.
plumguy is offline   Reply With Quote
Old 07-06-2005, 01:53 PM   #17
Noisy Pipe
What am I looking for and what will it tell me?
Umby is offline   Reply With Quote
Old 07-18-2005, 04:45 PM   #18
Noisy Pipe
Could someone shed some light on this one for me!
I have not long ago moved into my new home and have been experiencing difficulties with the water flow going through my mixer taps in the bath and upstairs sink.All of a sudden I hear a noise like air getting trapped in the sink tap and then water spurts out,air gap and then a bit more then a stop.This occurs a while after it has been turned on and off.The mixer tap in the bath for the shower throws a wobbler when I put the washing machine on and gushes out cold water when seconds before it had been set at a comfortable level for washing with both cold and hot water going through it.
It has been suggested to me that the water pressure has been set too low could it be that causing the trouble?:confused:
anita is offline   Reply With Quote
Old 07-18-2005, 05:21 PM   #19
Noisy Pipe
Just curious if your'e in a "new home" wouldn't it be under warranty. Also, are you on a well?
Old 05-17-2008, 12:00 PM   #20
Noisy Pipe
I know this is extremely old and someone just might see it. I am a newbie. I am on a well. My father-in-law, who installed the well, said it is supposed to do that. I know it has not been doing it the whole time we have been living in this (one of his 3 houses) house.
What would cause this hammer noise in the kitchen? It's the only place I hear it is when I turn on the water in the sink.
sandi is offline   Reply With Quote
Use of coupling fitting on gas pipe Fred Plumbing 3 01-28-2007 07:13 AM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 04:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
Gas dryer pipe jscholl411 Plumbing 1 06-07-2006 09:21 AM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 01:08 AM
