Noisy Drain Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-01-2005, 07:09 PM   #1
noisy drain pipes
Does anyone know how to quiet drain pipes running thru the walls? I have an upstairs shower, and the drain pipe is pretty noisy downstairs.
Thanks for any help. Dave
davidson924 is offline   Reply With Quote
Old 04-02-2005, 07:50 AM   #2
Hi Dave
Don't use the shower. Sorry I shouldn't try and be funny.
Anyway the steel or cast iron drains normally were quieter the newer PVC pipes. The water in the pipe will make noise. The only things that can be done is to relocate this noise or easiest is to muffle it. If you can open up one side of the wall and pack insulation around the pipe it should help a lot. When remolding I insulated all my interior walls for sound.
Mgmopar
MgMopar is offline   Reply With Quote
Old 04-08-2005, 02:08 AM   #3
Dave, I agree with the other reply about using cast iron pipes for such a drain, pack the area with insulation, and you may consider "RC channel" in case you re sheet rock your whole downstairs room, the channel holds the rock off the wall just a bit so sound will not travel through the wall. Easiest solution replace plastic pipe with cast iron and cover with black foam pipe insulation if there is room.Suzanne
diytiptoe is offline   Reply With Quote
