Noise When Toliet Tank Refills - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-28-2010, 09:10 AM   #1
when the tank starts to fill after flushing the pipes make a banging noise until the tank fills...what's the problem
2 threads on same issue merged
Moderator
comquat is offline   Reply With Quote
Old 08-28-2010, 09:17 AM   #2
normally its the angle stop or the fill valve. close the valve about halfway and flush it, if the problem goes away change the valve. if it doesn't, change the fill valve
the_man is offline   Reply With Quote
The Following User Says Thank You to the_man For This Useful Post:
comquat (08-28-2010)
Old 08-29-2010, 12:25 PM   #3
Actually I think I had that backwards... if you reduce the flow and it fixes the problem it's the fill valve. If the valve is halfway shut and it still makes the noise then its normally the washer in the valve. I have seen a PRV on the main line fail and make the same noise, so it could be other things, but the fill valve and angle stop are the easiest (and cheapest) places to start.
Old 08-29-2010, 12:40 PM   #4
Rewards Points: 472
Moderator
Just start?? or has this been a on going ? You say pipe's start banging ? are theae the copper in the wall ? A little more info. If it is the copper that is banging. Than a water hammer at the end of the copper pipes would be a fix.What that is is a i belive a 8" piece of copper with a cap on the end and than you sweat the other end to the copper line. Now you ask how am i going to get at the line? I belive you can go to the water heater and put it their. What this does is let the water bounce in the tube instead of in the line . This hange's off of the pipe . We will say like a T in the water line
del schisler is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Toliet TAnk Support hcbenton Plumbing 3 03-09-2010 08:48 PM
Noisy furnace (with recording of noise) Jeffrey HVAC 3 01-23-2010 01:17 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Nightmare water tank job Marvin Gardens Plumbing 6 11-04-2008 11:09 AM
