Old 08-07-2012, 05:56 PM   #1
Noise when hot water enters drain
Whenever we empty a boiling pot, or the dishwasher drains out hot water, or we continuously run hot water from the faucet we get a clicking/thumping sound from the pipe.
Is there anything that can be done to prevent this noise? I assume it is the expanding of the pipe from the heat? However I thought the PVC piping was made to withstand this?
atDev is offline   Reply With Quote
Old 08-07-2012, 07:11 PM   #2
The noise is from the pipe rubbing against the wood studs and/or joists it passes through, as it expands from the heat.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 08-07-2012, 10:23 PM   #3
It is a continuous click until all water drains or we put cold water down the drain. How can this be remedied? This is the first house we have ever had this problem on.
Old 08-07-2012, 11:16 PM   #4
call me E
TheEplumber's Avatar
Open the wall and enlarge the holes or replace with cast iron. The installation is rubbing on wood. No clean, easy fix.
Toilet flush issue. Paradiselost Plumbing 7 06-19-2012 01:47 AM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
water heater drip kdange1 Plumbing 5 05-04-2010 04:24 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 11:24 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
