Old 11-21-2007, 09:57 AM   #1
Non stop DIY'er!
Noise expert needed
Background:
Ranch house, full basement. This only starts when it's cold out. Turn on the water in the bedroom, mostly warm to hot water, and the drain vent starts banging, knocking. I guess it's expansion, but not sure how to stop it. I have access in the attic to it but not sure what to do.
bajaboy1 is offline   Reply With Quote
Old 11-21-2007, 11:58 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Noise expert needed
I'm no "expert" on anything, just a long-time DIYer.
If the vent pipe is loose, maybe you can clamp it down better where you can reach it, or tap wedges in around the pipe in the holes where it passes through wood framing to help alleviate the noise.
Plastic drain/waste/vent pipes are just naturally noisier than metal pipe. Sometimes you can wrap insulation around them or spray foam around them to help quieten them down.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 11-21-2007, 12:19 PM   #3
Non stop DIY'er!
Noise expert needed
Mike
Thanks for responding. I'll check the clearances around the holes.
Old 11-26-2007, 12:15 AM   #4
That one Guy's Avatar
Noise expert needed
That doesnt make sense? Are you sure its the vent or is this some type of water hammer? I dont know why the drain vent would make noise when the water is turned on.
That one Guy is offline   Reply With Quote
Old 11-26-2007, 10:00 AM   #5
Non stop DIY'er!
Noise expert needed
Well, I'll try to detail a little more. When warm or hot water is turned on in the master bath, a banging occurs behind the wall and up through the ceiling into the attic. This continues for a couple minutes after the water is turned off and done draining. No other water is being drained at this time, the water drain drops about 10 feet from there, along the basement wall and into the basement concrete and off to drain. The basement is well insulated, including that wall. This occured before I finished the basement anyway. This starts happening this time of year, when it gets cold out.
Old 11-28-2007, 08:22 AM   #6
Non stop DIY'er!
Noise expert needed
Any other suggestions? Vent piping seems to be tight through the attic. Got to be the venting pipe. I can hear it while the water drains while up in the attic. House is only 5 years old, if that matters.
Old 11-28-2007, 04:35 PM   #7
Noise expert needed
Do you have any pumps? water or sewage?
Old 11-29-2007, 07:33 AM   #8
Non stop DIY'er!
Noise expert needed
No pumps.
Can it just be the cold air coming down the vent from the roof and the warm water hits it as it's draining? I guess if water is flowing down the drain, wouldn't that create a small vacume pulling air down the vent?
Just thinking out loud here.
Old 11-29-2007, 11:03 AM   #9
Journeyman Plumber
Ron The Plumber's Avatar
Noise expert needed
What type of pipe is the vent? ABS, PVC?
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 11-29-2007, 01:07 PM   #10
Non stop DIY'er!
Noise expert needed
It's PVC.
Old 11-29-2007, 01:13 PM   #11
Journeyman Plumber
Noise expert needed
Now when hot water runs through plastic drain pipes, it can cause them to expand. This could be the cause.
Old 11-30-2007, 09:26 AM   #12
Non stop DIY'er!
Noise expert needed
Any solutions? Only happens when it's getting cold out. Would it help any to insulate the vent in the attic? That's the only place cold air hits the outside of it. Cold air coming down the pipe, I'm not sure what could be done there.
Old 11-30-2007, 09:40 AM   #13
Journeyman Plumber
Noise expert needed
No solution without accessing all related pipes.
Old 12-05-2007, 10:29 AM   #14
Non stop DIY'er!
Noise expert needed
What should I look for on all related pipes?
Old 12-05-2007, 10:41 AM   #15
Journeyman Plumber
Noise expert needed
Pipes too tight to the studs or floor joist.
power line noise sciguy125 Electrical 5 12-02-2007 02:39 PM
water pipes make noise after use eric Plumbing 2 09-25-2007 03:32 PM
GE side-by-side making a whining noise jkrodger Appliances 2 09-11-2007 03:45 PM
Toilet making Noise DSHMSH Plumbing 1 12-22-2005 05:33 PM
