Nohub Good For Joining Draining Pipes? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-05-2012, 10:52 PM   #1
Rewards Points: 682
nohub good for joining draining pipes?
A couple years ago we had some plumbers repair a tub/shower drain. They replaced the the overflow assembly and trap with plastic, and then they attached the plastic pipe to the remainder of the old iron pipe with a NoHub fitting.
I'm sure they knew what they were doing. So this nohub fitting is extremely reliable and long lasting? That rubber doesn't get stiff and crack with time?
darsunt is offline   Reply With Quote
Old 11-05-2012, 11:08 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
Years ago cast iron pipe was joined by putting the spigot end into the hub and packing it with oakum and then pouring lead on top of that- very labor intensive. Now, no-hub couplings are now used instead of hub & spigot joining methods- faster and reliable. No-hub couplings are the method of choice. Granted, like any product, there are inferior brands. But if installed and supported properly they should last a looong time. If its not leaking, no worries
Old 11-06-2012, 12:17 AM   #3
Rewards Points: 682
My shower drain pipe is coming out of the slab crooked. I'm thinking about busting out the concrete, and replacing the pipe and trap with plastic. So it would be good to No-hub the plastic pipe to the old drain pipe, and then put concrete over everything?
Old 11-06-2012, 12:27 AM   #4
Plumber
Rewards Points: 452
Sure, it's perfect for joining dissimilar types of pipe.
Buy a nohub coupling that is labeled CI x Plas. Cast iron is slightly smaller in outside diameter. So one side of the coupling is slightly smaller as well.
You'll probably find the outside of the existing CI pipe is corroded. You can use a steel brush to clean it up.
Possible small gas leak in black iron pipes WillK Plumbing 4 01-18-2012 12:07 AM
What's a good way to prevent frozen pipes in the garage? garya505 Plumbing 10 12-10-2011 07:51 PM
Insulating hot water heating pipes Rav HVAC 7 12-07-2011 01:58 PM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 11:29 AM
Portable air conditioners; who's got one? (No draining! Yet most say draining req'd?) Deck Appliances 1 07-16-2008 11:33 PM
