No Water From Well - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-18-2011, 09:44 AM   #1
no water from well
my pressure switch was tuning on and off last night so i turned it off (the pump) this morning put it bk on and the pump will not turn on? help i know very little about pumps....pls
imjustsayin66 is offline   Reply With Quote
Old 07-18-2011, 10:05 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
If your pump is running and no water there usually is a hole in the water line. If your pump is not running there are several things it could be. First thing I would check is the points as you said it was cycling on and off, that will usually burn the contacts. Turn the power off and sand the points and give that a try. If that doesn't do it the pump may be bad, or a wire may be burned or lose or your breaker may be kicked. It may be the regulator is shot. You will just have to start and see which it is.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 07-18-2011, 10:17 AM   #3
Newly Retired
tuchodi's Avatar
Is it a deep well pump or a shallow well pump that sits in your basement or pump house? If it is a deep well pump you will also have a starter box which might be faulty. or as said earlier it may be a wire or the pressure switch.
tuchodi is offline   Reply With Quote
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
Well Water snuggles2010 Plumbing 3 04-13-2010 02:36 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
