| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Hot Water Lines in Bathroom Installation
by Expert Village
We are going to talk a little bit about how we are going to get water to our shower, our toilet, our new washing machine, and our sink. What I had to do was I had to find a place where I could pull cold water and also pull hot water and being that these... Read More »
Cold Water Lines in Bathroom Installation
by Expert Village
Ok. Now, we're going to talk about how we ran cold water. Again, our cold water line was already existing here. So, I cut off the old pipe added a ninety. And, we've started running it along the wall here. And, then here we have a "T" that runs up and... Read More »
The Beginning of Installing a Ball Valve
by Expert Village
Hi! This is John on behalf of Expert Village. In this video clip, I will show you step 1 for installing a ball valve. I am going to be installing a ball valve on this pipe. This pipe is a hot water pipe, and I know that because when I trace it back, it... Read More »
How to Install Pipes Under the Kitchen Sink
by Expert Village
I’m Lee. I have a degree in architecture and about ten years construction experience, and today we are replacing the hot water pipe and valve. Now we’ve already installed the valve, which is a two outlet valve- one for the sink and one for... Read More »
Using Solar Panels for Water Heaters
by Expert Village
What you see here is a solar water heater. So totally different to photovoltaic or to solar electricity. This one is just using the sun to heat up water. And when you look close, I opened it up for you that you can see what's going on there. In here is... Read More »
