No Water In Shower And Im Out Of Things To Try - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-26-2012, 03:35 PM   #16
Rewards Points: 344
I would call Delta and ask for a complete replacement.
http://www.deltafaucet.com/customers.../warranty.html
You stated that the Plumber verified you had incoming water.
tribe_fan is offline   Reply With Quote
Old 11-27-2012, 09:23 AM   #17
you know that may be the best plan. Not sure why I havent done that yet.
loki993 is offline   Reply With Quote
Old 11-27-2012, 12:02 PM   #18
Rewards Points: 344
You may want to get the documentation on adjusting the valve - I'm not sure, but maybe its possible to get orientated where nothing works? http://answers.yahoo.com/question/in...=1006052706057
Here is a video I found.
http://www.gilbertplumbing.com/episo...bpedia_001.php
Old 11-27-2012, 02:21 PM   #19
JOATMON
ddawg16's Avatar
Rewards Points: 2,116
I think we need to back up and summerize all the facts....and clarify a couple of things.
With the valve removed and just the test cap installed you still do not get flow? Correct?
Including no hot or cold water?
Additionally, you do not get any hot or cold flow to the adjacent sink faucet?
You have a tankless water heater that supplies the rest of the house as well?
Water pressure is fine on all the other fixtures?
Please clarify/confirm the above.
Old 11-27-2012, 02:38 PM   #20
With the valve removed and just the test cap installed you still do not get flow? Correct? Correct
Including no hot or cold water? Correct nothing
Sink faucet is fine. I was talking about the shower faucet. It not a shower only, it has a faucet for the bath and a shower head for the shower.
Yes
Yes
Answers in the quote
also I called delta and they said they couldn't do anything about the warranty because the shower was i the house when I bought it? The house was remodeled. I don't get it.
Old 11-27-2012, 02:47 PM   #21
JOATMON
ddawg16's Avatar
Ok....this helps.....we know it's not your water heater....
so....if you get NO flow with just the test cap on...neither hot or cold.....
Have you tried removing the test cap so that you have both your hot and cold going into an open rough-in body?
I would be turning off the water...turning off the water to the hot water heater....removing the cap/valve on the shower.....and turn the water back on...
If nothing comes out....it's NOT the water heater....should at least have cold water. If not....the blockage is somewhere before the rough-in body.
I think you should try compressed air.....and blow it back towards the water heater like I suggested above.
Old 11-27-2012, 02:56 PM   #22
Have you, or your plumber tried what I suggested?
Ishmael is offline   Reply With Quote
Old 11-27-2012, 03:08 PM   #23
Not yet, but I do need to. I don't have a compressor so no compressed air. Ill have to go to my dads and get an air tank for that. I probably wont be able to do that until the weekend
Old 11-27-2012, 03:11 PM   #24
JOATMON
ddawg16's Avatar
Can you borrow a water hose from a neighbor? Put together some connections and use their water pressure to maybe flush the line?
Old 11-27-2012, 03:12 PM   #25
Rewards Points: 344
Call them back and say you bought it and installed it, but lost your receipt.
Old 11-27-2012, 03:27 PM   #26
That's what Im thinking. Butt hey did take my name and zip code don't know if they keep records. I could have my sister call or something though. I just find it a bit silly that the person that installed it in the house was never intended on owning it, so for all intents and purposes Im the first owner, though I didn't actually but the ting. Otherwise the plumber that installed it is the warranty holder.
Old 11-27-2012, 03:47 PM   #27
Plumber
TheEplumber's Avatar
Rewards Points: 904
Did you say this is a balancing valve? Is the spool separate to the cartridge?
Old 11-27-2012, 07:14 PM   #28
Yes its a balancing valve and no the spool is in the cartridge. Cartridge seemed fine I shook it and the spool moved I replaced it anyway and its still good.
Old 11-27-2012, 07:37 PM   #29
Rewards Points: 258
i have never taken a shower/bath tub valve apart before but if i was haveing this issue i would be looking for a way to check that the lines from the last "T" to the shower valve were not blocked. i.e. taking apart the shower valve and turning the water on to see if water comes out.
redman88 is offline   Reply With Quote
Old 11-28-2012, 07:13 AM   #30
The plumber did that. He pulled the lines off of the shower valve and they are fine.
Water issue in bathroom at base of the tub and shower plumbing wall NeverEnoughTime Plumbing 3 10-24-2012 11:23 PM
Low water pressure in shower Bluew126 Plumbing 5 08-28-2012 06:47 PM
What is the standard method of water pressure test for shower plumbing please? Andy21 Plumbing 10 10-28-2011 04:06 AM
Only warm water in shower - Pfister pvstansel Plumbing 1 09-25-2011 12:42 PM
Preference for installing tub spout? dolvio Plumbing 7 02-11-2009 10:53 PM
