Old 10-06-2012, 08:08 PM   #1
No water from shower faucet
I have water to sink and toilet but can't get any water flow to tub shower, there is no inside cutoff. What do I need to do.
Sandie is offline   Reply With Quote
Old 10-06-2012, 08:10 PM   #2
Both hot and cold?
Not the shower or the tub?
Old 10-06-2012, 08:12 PM   #3
No water at all and it is only one round handle
Old 10-06-2012, 08:13 PM   #4
Shower an tub use same water supply
Old 10-06-2012, 08:14 PM   #5
Super Moderator
If you have a tub spout and shower head and no water comes out of either---the cartridge is clogged and needs replacing--
If it's a shower only----it's likely the cartridge---but might be the filter screen at the shower head---unscrew the head and test the valve without it.
We will help you figure out the repair if you give us more details---Mike----
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 9 05-04-2012 11:56 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Potential Water Issue in New Shower? cobrakai Kitchen & Bath Remodeling 4 02-12-2011 06:36 PM
shower leak..hot water tank leak...HELP!!! Drie Plumbing 6 06-30-2010 03:12 PM
Does not fully go from faucet to shower desimonkey Plumbing 1 04-21-2009 03:59 PM
