No Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-10-2012, 09:07 AM   #1
No water Pressure
Hi,
I am having an issues with the water pressure in my home, i can not get pressure to build up in my H2ow precharged water tank. I first thought that the valve in my well was caked with dirt or otherwise broken it has been replaced and the problem persists. I can here my pump pulling water through but i can not get any water pressure, i think i might be priming it wrong and have no manual to go by any help would be greatly appreciated.
jakedawg is offline   Reply With Quote
Old 01-10-2012, 09:24 AM   #2
the Musigician
DangerMouse's Avatar
Do you have a pressure tester? What is PSI in the tank bladder?
DM
Old 01-10-2012, 09:25 AM   #3
the Musigician
...and you say the valve.... do you mean the check valve from the well? Is the arrow pointing in the right direction?
DM
Old 01-10-2012, 09:26 AM   #4
Zero nothing
When i attempt to add air the needle bobs up and down quickly but does not build pressure
Old 01-10-2012, 09:32 AM   #5
the Musigician
hmmm.... possibly a hole in the bladder?
DM
Old 01-10-2012, 09:36 AM   #6
That's what i think but wanted to see if i was missing something simple thanks for the input
Old 01-10-2012, 09:39 AM   #7
the Musigician
How old is the tank? Time to replace? Or repair?
DM
Old 01-10-2012, 09:55 AM   #8
Rewards Points: 14,010
Try pushing down on the valve stem with a finger nail, if water comes out the badder has a hole in it. There should never be water in that valve.
Old 01-10-2012, 12:16 PM   #9
Yeah it does that must be my problem thanks for all the help time to replace it
Check valve gimaarob Plumbing 13 10-27-2011 10:13 PM
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 07:24 PM
hot water pressure much lower than cold water pressure lockingpin Plumbing 5 12-26-2009 04:23 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 11:19 AM
