No Water From My Kitchen Faucet? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-06-2011, 11:47 AM   #1
No water from my kitchen faucet?
When I turn on my kitchen faucet, the water barely drips out. I have a spray hose that is separate from the faucet. That still works fine. Essentially I have not water running out of my faucet.
This happened out of nowhere. The faucet was working fine one minute, and then there was no water the next!
Is this something easy to fix or do I need a new faucet?
bizzy1028 is offline   Reply With Quote
Old 06-06-2011, 11:50 AM   #2
Seasoned DIYer
Rewards Points: 150
Check the aerator. if that doesn't fix it, you may have a foreign object clogging the inlet at the cartridge which is only 3/16" in size.
HVAC_NW is offline   Reply With Quote
Old 06-06-2011, 11:54 AM   #3
Thanks! I hate to sound like such a girl, but i am...
What is the aerator? How do I check it?
Old 06-06-2011, 12:45 PM   #4
The aerator is that round piece at the bottom of the spout where the water comes out, you will need pliers to remove it, wrap a rag around it first so you don't damage it.
http://www.ehow.com/how_2073786_fix-sink-aerator.html
pinecone12 is offline   Reply With Quote
Old 06-06-2011, 01:27 PM   #5
Thanks so much! I'm going to go home and give it a try!
Old 06-06-2011, 04:04 PM   #6
Tizzer's Avatar
Rewards Points: 452
Watch the order and direction of the washers & all if you take the aerator apart to clean. Soaking in vinegar works or just get a new one, they're fairly inexpensive.
Tizzer is offline   Reply With Quote
Old 06-07-2011, 08:35 AM   #7
Plumb or Die!
This is always my favorite plumbing problem, in the real world and online! So was the aerator the problem?
plumber666 is offline   Reply With Quote
Old 06-07-2011, 03:16 PM   #8
NOPE!
I managed to remove the aerator and it actually looked pretty clean. Just to check, while the aerator was off, I turned on the faucet and still, all I got was a little drippy water.
I guess the next step is to replace the faucet???
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Hot water issues in kitchen marmistheman Plumbing 2 01-23-2011 04:54 PM
taste of chlorine in water from newly installed kitchen faucet ilyaz Plumbing 4 04-20-2010 04:14 PM
Replaced kitchen faucet - now less hot water? sde Plumbing 5 05-26-2009 04:16 AM
Help! hot water won't stop running despite faucet changes. nodak_luke Plumbing 4 12-14-2007 06:38 PM
