No Water At Moen Shower Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-10-2016, 09:37 AM   #1
Lord of Slums
Rewards Points: 1,974
No water at moen shower valve
Hot water heater went. Cut out old heater and capped the water lines. So the cold works every where in the house. However now the shower in the bathroom does not work. I wonder why? Does that sound like a bad cartridge? The shower had work before pulling the water heater. The toilet and sinkhave water going to them.
mj12 is offline   Reply With Quote
Old 06-10-2016, 09:58 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 674
Re: No water at moen shower valve
If you don't have pressure on the hot side then a Moen pressure balancing valve will not work.
I read that you have not installed the new heater?
Old 06-10-2016, 05:15 PM   #3
Rewards Points: 1,952
No hot water at shower no shower at all. It's normal.
Ghostmaker is online now   Reply With Quote
Old 06-10-2016, 07:50 PM   #4
Lord of Slums
No heater yet. The whole house is more just storage but I do eat and shower there from time to time. I clean up and do my laundry there before heading home on dirty days as well.
Old 06-10-2016, 08:48 PM   #5
If you like cold showers you need to run the cold water to the hot side when you do not have a hot water tank. So you have water on both inlets.
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Leaky ball valve at incoming water line Bipin1948 Plumbing 5 10-03-2011 05:21 PM
Only warm water in shower - Pfister pvstansel Plumbing 1 09-25-2011 12:42 PM
hot water check valve? Ultrarunner2017 Plumbing 7 01-30-2009 01:36 PM
