Old 10-30-2006, 10:17 PM   #1
No water from kitchen facuett
I get no water from my kitchen faucet, but the sprayer works fine. What could the problem be?
rmh218 is offline   Reply With Quote
Old 10-31-2006, 03:19 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Check areator of the front of the spout, remove it, turn on faucet, if good flow, then clean this out.
Ron The Plumber is offline   Reply With Quote
Old 10-31-2006, 10:03 AM   #3
I tried that when the flow was low now I get no water at all. Only way to get water is through spayer. Should I change faucet? Or could there be another cause/solution?
Old 10-31-2006, 12:49 PM   #4
I blame ProWallGuy
What type or brand of faucet is it?
I suspect you have a damaged diverter or debris caught in the diverter pathway.
Double A is offline   Reply With Quote
Old 10-31-2006, 01:53 PM   #5
I am guessing that you have a single handled faucet. These usually have a cartridge in them that can get clogged or "O" rings go bad. Remove the cartridge (after turning off the water supply valves) And check it. Make sure to note the orientation of the cartrige before you remove it (maybe even mark the top center with a magic marker). Some can be installed reversed and will not work.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 11-01-2006, 11:01 PM   #6
It is a Glacier Bay faucet. Is this a good brand? It came with the house.
Old 11-01-2006, 11:13 PM   #7
Journeyman Plumber
Glacier Bay is a cheap thow-away faucet, I recommend getting a quality facet, like AM/Std or Moen faucet, one you can depend on.
Old 11-02-2006, 11:37 AM   #8
I blame ProWallGuy
Glacier Bay is the Home Depot house brand. You know, the ones that are sold off of the pallet displays in the middle of the plumbing aisle?
They are considered disposable. Replace the faucet. Moen, American Standard, Kohler, Delta, Gerber... they all make good faucets that you can get repair parts for.
GL
Old 11-02-2006, 05:33 PM   #9
I agree with Ron and Double A. Most people don't think about replacements parts that may be needed down the road. If you stick with the "name" brands, you can usually find any parts you may need.
Gravity Hot Water Recirculating Loop Questions harleysilo Plumbing 2 02-06-2007 04:28 PM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 08:51 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Old Water Supply Lines in Kitchen and Bath Faucets skittlzski Plumbing 2 08-08-2006 10:13 AM
help Chuckman Off Topic 8 06-15-2006 11:06 PM
