No Water From Hot Side Of Faucets - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-30-2011, 10:53 PM   #1
no water from hot side of faucets
A friend of mine tells me that every couple of months when he opens up the hot side of any faucet he gets nothing. no water, no air, nothing.He says if he opens the relief valve on the water heater he also gets nothing. But after opening relief valve he can then go to any faucet and get hot water. It doesn't happen again for a couple of months. Could it be a problem with the flexible line on hot side or possibly a dip tube problem? It is a natural gas heater.
sthomp is offline   Reply With Quote
Old 11-30-2011, 11:10 PM   #2
Perhaps a problem with heat traps on the water heater...
http://waterheaterreviews.com/what-is-a-heat-trap
That can also be a part of a dip tube.
Be sure cold is going to cold and hot going to hot. Should be marked on the water heater top.
Billy_Bob is offline   Reply With Quote
Old 12-01-2011, 07:36 AM   #3
biggles's Avatar
that relief should blow off. anytime it is manually lifted he need to flush it out and remove the hot pipe and check that dip rod the hot water rises up.....that is street pressure from the cold side something is floating inside that tank to hold back 50PSI house pressure or even more....might also might have mineral buildup on the hot line out....find out when he opens the drain with a hose connected that also should be cold water pressure if thats blocked the tank is fouled up
MAYTAG Side X Side dripping Water Dispenser junior1263 Appliances 1 10-23-2010 07:34 PM
New Faucets - Rural Water Well Supply terra3 Plumbing 2 02-25-2010 05:41 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Faucets - Reduced Water Flow wallydj Plumbing 5 02-18-2008 04:35 PM
