Old 12-23-2007, 07:16 PM   #16
GB
No water flow from house supply to fridge
Originally Posted by bigMikeB View Post
There is probably a tap a line valve feeding the poly pipe and it's corroded closed. You need to forget back flushing and locate the valve for the poly. This is a very common issue.
If the valve is corroded closed ( house is only 4 years old), it is in the ceiling somewhere (where the manifold is). I'm not willing to open any drywall to hunt for it, so if it's a corroded valve, I'll have to live with it.
garyb123 is offline   Reply With Quote
Old 12-23-2007, 07:38 PM   #17
Master General ReEngineer
Bondo's Avatar
Picture shows it running up into ceiling. I don't have more pictures, of this line. Question is, can I get to it's source, without opening wall / ceiling?
What is Above that Ceiling,..??
Is there a 2nd floor,..?? or a Crawl Space,..??....
If it's a crawl space,..... There's Got to be an access to it Somewhere.........???....
Old 12-23-2007, 08:19 PM   #18
Gary - If you can't find the source where it connects into your supply - whether it is a Tee or a valve -then you should leave it alone until you do. What if you had connected your hose in an attempt to backflush and it burst the tubing inside the wall ??
Can you contact the builder and ask ?
tribe_fan is online now   Reply With Quote
Old 12-23-2007, 11:35 PM   #19
Union HVAC Tech.
The valve needs to be located and replaced, that is why codes don't allow saddle taps any longer. They fail often.
bigMikeB is offline   Reply With Quote
Old 12-24-2007, 01:10 AM   #20
GB
2nd floor with all supply lines not accessable.
Old 12-24-2007, 01:12 AM   #21
GB
tfan,
At this point, I think you're right to suggest call to builder!
Old 12-24-2007, 01:17 AM   #22
GB
bigMike,
If you are referring to a saddle valve feeding the 1/4" poly line, there isn't one. The valve feeding it is threaded onto 1/2" house supply line. With your previous post, I thought you were referring to valve feeding the 1/2" line, at PEX manifold in ceiling.
Old 12-24-2007, 08:08 AM   #23
Is the manifold accessible ? Does its look like one of these ?
http://www.pexsupply.com/CategoryPre...ID=518&brandid=
If everything else is working off the manifold - this is your "source" - you need to identify the one that goes to the line to the fridge.
Old 12-24-2007, 01:27 PM   #24
GB
From the limited pictures I took while my house was being built, yes the manifold looks like one of those pictured. Problem is, the manifold is in ceiling and not accessible. Plus, assuming there are additional manifolds, I don't have pictures of them. Therefore, who knows where the source is. I'm not willing to tear up drywall, just to "look around". Fortunately, only fridge is affected. So, if I have to live with it, I will. A call to the builder might be my best option, at this point. What a pain - I feel like I'm attempting a repair with my eyes closed. Do you have a pair of x-ray glasses??
No Water Flowing To Fridge garyb123 General Discussion 5 12-24-2007 01:28 AM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 12:59 PM
Loss of water pressure in my house... stormyjas Plumbing 6 02-15-2007 11:36 AM
Adding a new water line to dishwasher and fridge? PMichaud Plumbing 18 01-05-2007 08:00 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
