No Vents - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-29-2009, 08:04 PM   #1
No vents
my plumbing in my house is severely outdated and not up to code it is leaking underneathe the toilet where it goes to the main line also none of my stuff in "vented." If I Run several vent tubes up the walls can I tie them all together the punch a hole in the side of the attic wall to pipe it outside?
jeepdogsfishing is offline   Reply With Quote
Old 03-29-2009, 08:44 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Jeep,
Did you have a pro come out and take a look at the DWV system or have the main rodded like I suggested from your other thread?
Old 03-29-2009, 08:49 PM   #3
I didn't have a pro come out since its sunday, but i went to the attic and looked down the walls and they don't have vents , they just have a pipe that goes down and there arent any vents in the crawl.......can i install a vent by tapping into the pipe in the wall and running a vent to the attic and using aa valve or will this work
Removing some vents rdmccaw HVAC 4 10-22-2008 01:00 PM
Big trouble with gable vents! Beth777 Building & Construction 9 08-11-2008 07:32 AM
ridge/soffit vents not enough?? cbice74 Roofing/Siding 1 06-16-2008 05:02 PM
sofit vents + gable end vents no ridge vent mattg1970 Roofing/Siding 5 10-18-2007 09:47 AM
blow power of vents mcvane HVAC 5 08-11-2007 03:28 PM
