Old 08-03-2012, 12:18 PM   #1
No spark at pilot?
I cannot get a spark at the pilot when pressing the piezo. Upon taking the piezo wire loose, I felt a shock when pressing it. Is the problem farther down the line?
deweech is offline   Reply With Quote
Old 08-03-2012, 12:21 PM   #2
No spark at pilot?
What options do I have to repair the water heater? It is only a couple of years old I am told.
Old 08-03-2012, 12:32 PM   #3
No spark at pilot?
may be the wire is pinched somewhere and sparking there instead of at the pilot.....
Old 08-03-2012, 02:49 PM   #4
biggles's Avatar
No spark at pilot?
pilot assembly isn't grouned rust/screw loose..if your getting a hit from the ignitor cable that is solid....check it to the pilot assembly like a C wire on a car into a distributor cap
Old 08-04-2012, 02:59 AM   #5
sacramento plumber
wctekkk's Avatar
Location: born and raised in San mateo ca. living in Sacramento Ca for 3 years now.
No spark at pilot?
Remove orange wire from Piezo igniter and install a jumper wire in its place. Hold the other end of the
jumper by the wire insulation or using an insulated tool, next to an unpainted surface such as the feed
line or gas valve and depress the Piezo igniter. If there is a spark, the igniter is OK, the pilot is not
functioning and must be replaced,
wctekkk is offline   Reply With Quote
Spark Pilot goes out in 2 secs so no time for Burners to ignite Liberator HVAC 6 01-25-2012 10:40 PM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 04:29 PM
Intermittent pilot spark ignition question cody69 HVAC 4 02-16-2011 09:21 PM
Changed spark igniter. Get pilot but gas never comes on... verycold HVAC 25 01-22-2011 04:55 PM
heat turns pilot light off tclarkmd HVAC 3 10-12-2007 10:37 AM
