No Shut Off For Outside Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-08-2012, 06:26 PM   #1
No shut off for outside faucet
My house was built sometime around 1920. I have a basement so i can see most of the plumbing lines. I have 1 outside faucet. I've followed that to a spot that has a 90 degree angle with two shut offs. But, when i turn either one of them, it seems to do the same thing, which is turning off the water to everywhere. I can't seem to find a way to turn off just the outside faucet. Is it possible that the home doesn't have a shut off for the outside faucet? If that is the case, is disconnecting the hose outside enough to prevent the pipe from freezing? It is an older looking faucet outside, not a newer frost free type. This is my first winter in this home. Thanks
cgauld is offline   Reply With Quote
Old 11-08-2012, 06:33 PM   #2
Rewards Points: 332
Trace the water line for the outside faucet. The main will angle similar to the faucet line.
It may be in a bathroom or kitchen cabinet or possibly the garage too.
sgip2000 is offline   Reply With Quote
Old 11-08-2012, 06:40 PM   #3
Rewards Points: 12,804
It's far more common to not see a shut then to see one.
It a good idea to add one under the house so if you need to work on it as you found out you do not have to shut the whole house down.
Is it going to freeze? Depends on where you live.
A really good idea would be to change it to one like this.
http://www.homesmsprealestateblog.co...illcock1_2.jpg
This style shut off the water under the house not outside, still would have to remove the hose when it gets cold or it's going to freeze.
Old 11-08-2012, 06:43 PM   #4
DIY staff
Rewards Points: 7,174
A lot of old places did not have a shut off for the hose bib---the old places were such heat loosers that the pipe stayed warm enough that they never froze---
Just add that to your list of things that need attention----do not insulate in that area until you change the hose bib to a frost free valve---and a shut off.
The poor insulation around the pipe is what keeps it from freezing.
Old 11-09-2012, 04:41 PM   #5
Rewards Points: 243
Why not try one of those insulated outdoor faucet freeze caps?
chemman is offline   Reply With Quote
Old 11-09-2012, 08:29 PM   #6
Rewards Points: 3,342
And if you can't do any of the above get a heat tape on it,before it freezes.
Canarywood1 is offline   Reply With Quote
Tags
freeze , outdoor , shut off
Water main shut off and tub faucet still leaking Jbauer Plumbing 2 07-17-2012 09:56 AM
Why would faucet leak when shut off at main supply? barbienot Plumbing 6 01-29-2012 08:00 PM
Adjusting a spring loaded auto shut off faucet PAO Plumbing 14 03-31-2011 11:15 AM
No access to Main shut off until spring and kitchen faucet is broken calgal Plumbing 28 03-13-2011 12:53 PM
Tub Faucet won't shut off moashalex Plumbing 6 11-25-2009 12:43 AM
