Old 05-24-2007, 05:03 PM   #1
NO Shower water!!! HELP!!!
We just got done remodeling our bathroom. Everything was working well, three people took showers, and water ran fine, now all of a sudden hardly any water come out of the bath faucet when turned on, just like a COLD trikle, HELP me PLEASE! anyone know why this happened all of a sudden, can't really afford to call the plumbers in to redo it all
ssla is offline   Reply With Quote
Old 05-24-2007, 08:58 PM   #2
Eibwen
I would pop off the shower head first and see if something that was in the pipes ended up lodging there blocking the flow. Check if water flows with the shower head off..
What plumbing was disturbred duing your remodel?
Sammy is offline   Reply With Quote
Old 05-25-2007, 09:31 AM   #3
I hope you didn't install a cheap band facuet... may be the core part is no good and need replacement, replacing them do not requires rebuilt anything though... just open up and replace the removable core part.....
KUIPORNG is offline   Reply With Quote
Old 05-25-2007, 11:25 AM   #4
Journeyman Plumber
Ron The Plumber's Avatar
What brand is this bath faucet?
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Water Pipe Size for Double Shower froddan Plumbing 12 08-03-2007 09:46 PM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
Shower Body, Toilet Water Supply Rough helpless handyman Plumbing 5 11-06-2006 09:51 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Hot water boosting shower pump Sosh Plumbing 3 04-17-2005 10:52 PM
