No Outside Water Spicket - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-11-2011, 11:11 AM   #1
no outside water spicket
Can I run a water line from my washer line to the outside for a hose hookup?
mpinzino is offline   Reply With Quote
Old 08-11-2011, 11:33 AM   #2
Rewards Points: 1,448
Yes you may.
If the washing machine pipe is 1/2 inch or less and the water pipes closer to the water meter are fatter than 1/2 inch, it would be better to hook up the outside faucet to one of those using 5/8 inch pipe all the way, even if the length of new pipe is longer. This way the outside faucet has better pressure.
Old 08-11-2011, 12:29 PM   #3
thanks
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
Low/No Hot Water Pressure after changing Elements Onehipcat Plumbing 18 08-05-2010 10:16 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
