No Membrane For Shower...? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-15-2010, 09:36 PM   #1
Question
No membrane for Shower...?
I've recently hired a "handy-man" to help construct/tile my bathroom. After installing PEX, he has insisted that since my bathroom is on the lower level of my house and on a concrete base, we do not need to install a membrane. I'm thinking this isn't so smart because even though the water goes straight into the concrete if there happen to be any leaks, we have no idea where that water goes after the concrete base or if it will affect any other areas of the house. He's also never heard of the Kerdi product that seems to be very popular on the contractors site. Additionally, we're tiling using marble and he wants to use 1/4 inch grout lines, but reading up on marble, it looks as if 1/8 or smaller is better. Any thoughts? Thanks so much for any inputs.
Jaguar
ShutOut13 is offline   Reply With Quote
Old 10-15-2010, 10:27 PM   #2
HVAC / Plumbing
hire someone that knows what their doing. Not a handy man
kenmac is offline   Reply With Quote
Old 10-15-2010, 10:38 PM   #3
He showed me his PA license info, so unfortunately I feel a bit misled. I'm guessing this means you think no membrane = problems as well?
Old 10-15-2010, 10:44 PM   #4
HVAC / Plumbing
I don't know what a PA license means. In my location, you have to be a state certified plumber. Not to do the tile work, but to install /construct a bath, run water lines, connect drain, etc,
Old 10-16-2010, 06:17 AM   #5
DIY staff
Rewards Points: 7,174
That shower base need water proofing----There are three common methods---
Membrane under the base
Paint on waterproofing on top with the proper drain--Hydroban by latacrete is one
Surface membrane on top --Schluters Ditra is one--
You do not want this guy building the base for you----Do a 'flood test ' before tiling---Shower Construction Info (a collection of posts) - Ceramic Tile Advice Forums - John Bridge Ceramic Tile
Plug the drain and fill with water for 24 hours----I don't think his pan would pass that test.---Mike---
Old 10-16-2010, 01:29 PM   #6
Chicago, IL
Michael Thomas's Avatar
If you ever try to floor the basement with any sort of moisture absorbent material (for example carpet or engineered wood flooring) there is a very good chance it will absorb moisture from the slab, often out to a considerable distance from the shower.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 10-16-2010, 01:58 PM   #7
Rewards Points: 252
I'll second one of the previous posts - do yourself a favor and head over to the John Bridge Tile Forum. Some of the nicest and smartest guys in the business contribute to that site. Warning - you may get more info there than you can handle =)
good luck!
mazzonetv is offline   Reply With Quote
The Following User Says Thank You to mazzonetv For This Useful Post:
oh'mike (10-16-2010)
Torch on roof membrane on deck canada55 Roofing/Siding 36 03-03-2011 02:18 PM
Kerdi Membrane Question/ Vapor barrier wrea398 Building & Construction 2 09-04-2010 08:40 PM
Vent dryer through flat membrane roof Vince Rosati General DIY Discussions 6 11-02-2008 02:11 PM
roof leak and EPDM membrane dbai Roofing/Siding 8 10-28-2007 05:16 PM
Shower membrane mc52 Building & Construction 2 01-27-2007 09:59 PM
