No Hot Water When Central Air Is On - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-14-2011, 08:03 AM   #16
Apparently not.
I've never lit (or relit) the pilot light in the hot water heater (I didn't even know it has a pilot light!), only the furnace.
Alert is offline   Reply With Quote
Old 07-14-2011, 07:30 PM   #17
Rewards Points: 1,534
Are you sure the plumbing is done correctly? Maybe you are drawing hot water only from a furnace (or boiler) tankless coil and the stand alone water heater in the crawl space is not sending any water anywhere. THen when the furnace quits, no hot water.
AllanJ is online now   Reply With Quote
Old 07-14-2011, 09:20 PM   #18
pictures of everything would help a lot
Old 07-14-2011, 09:36 PM   #19
Mad Scientist
I looked up the "furnace" model number, and it's actually a boiler. So if you have a domestic hot water coil in the boiler providing your hot water, that would explain why you get no hot water when the boiler pilot is out.
McSteve is offline   Reply With Quote
low domestic hot water flow with tankless coil mike42 HVAC 28 11-24-2011 08:35 AM
No hot water past the valve at top of hot water heater-?- Daulton Plumbing 4 04-03-2011 02:47 PM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 03:01 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
