No Hot Water From Water Heater Unless The Furnace Is On - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-08-2011, 08:51 AM   #1
Question
No hot water from water heater unless the furnace is on
Ok here is the setup cold water goes into my elec hot water heater and comes out and goes into the inlet of the furnace then the outlet outlet of the furnace goes to the house. When I have the furnace on I get HOT HOT HOT water but when my furnace is off I only get water that is prob about 100 degrees. I do not want to run the furnace in the summer. What is the best way to set this up?
HELP
karlmarsh is offline   Reply With Quote
Old 06-08-2011, 10:03 AM   #2
Rewards Points: 1,442
Add some T's and valves so the hot water coming out of the electric heater can skip past the inlet to the furnace and rejoin the outlet from the furnace. One valve goes in the middle of this bypass, the other valve just before the inlet to the furnace. In summer you close off the inlet to the furnace and open the bypass. In winter you close the middle of the bypass and open the inlet to the furnace (and also turn off the power to the electric heater).
The way you have it now, the hot water loses much of its heat passing through the cold furnace in summertime.
Old 06-08-2011, 10:20 AM   #3
Cool
Thank you so much for a fast reply!! I will try that and post my results for others to see
Old 06-08-2011, 03:28 PM   #4
Rewards Points: 160
Also check the temperature setting on the electric water heater. It may be set relatively low to act as a pre-heater only with the furnace doing the final temperature rise.
I'd try that first before doing a bunch of replumbing. That said, the heat loss to the furnace may make it worthwhile to do so anyway.
cgoll is offline   Reply With Quote
Tags
hot water
gas fireplace with same vent as furnace & water heater? Van3 HVAC 0 01-30-2011 05:21 PM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 11:43 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 11:33 AM
Installing a Tankless Water Heater infoiam Plumbing 4 11-10-2008 10:59 PM
