No Hot Water Supply After Removing R.O. System - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-04-2010, 05:18 PM   #1
No Hot Water Supply after Removing R.O. System
Today I removed the reverse osmosis unit from under my kitchen sink. Naturally, the unit had little water lines going all over the place, which I removed.
Now I just have the cold water line going from the wall to the faucet, and the hot water line going to the dishwasher and the faucet.
When I turned the water back on (both hot and cold knobs), I have nothing coming from the hot side.
I removed the line from the wall to the faucet, and there still is no water coming from the wall spigot.
I turned on the dishwasher to see if it would pull any water, and it did not.
Any ideas what happened with my hot water supply? It's fine in the rest of the house.
EZ Gruv is offline   Reply With Quote
Old 07-04-2010, 10:18 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
The rubber washer inside of your angle stop has come loose from the end of the stem and is plugging the supply outlet of the stop.
Journeyman Plumber
Old 07-04-2010, 10:22 PM   #3
Actually, I figured it out. The ball portion of the valve had broken off. I picked up a new valve and everything is fine now.
Purging Forced Hot Water System dwlodyka Plumbing 4 10-22-2009 07:56 AM
Desiging a manifold water system? BowDown Plumbing 1 07-20-2009 11:00 AM
water coming up water supply liner candaneh Plumbing 3 03-30-2009 09:50 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
boiler / Over-pressurizing cparke HVAC 1 05-21-2008 05:54 AM
