No Hot Water In Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-02-2013, 05:45 PM   #16
Rewards Points: 12
Originally Posted by Mark15 View Post
if there was hot water in the sinks then it was producing hot water. I have not yet ruled out cold water cross over.
It could be a hot water heater volume issue. Sink output is significantly less than a tub or washing machine. So you get hot water from the sink but not enough when you need a lot of it.
djlandkpl is offline   Reply With Quote
Old 03-02-2013, 05:56 PM   #17
Rewards Points: 1,766
If you have a recirculating system you will usually find a pump on your ho twater line by the tank.
Do you have single handle faucets in your sinks and what brand.
Old 03-02-2013, 06:24 PM   #18
I don't see a pump near the hot water lines. There is a single handle faucet in the kitchen but I'm sure what kind, there's no brand written anywhere.
Mark15 is offline   Reply With Quote
Old 03-02-2013, 06:38 PM   #19
Rewards Points: 12
Please post the make and model of your tankless. I'm thinking it fires in stages depending upon demand and it's not working right. Or it's something simple like the temperatue setting was changed and is too low.
Old 03-02-2013, 06:52 PM   #20
Utica SFH3100ST. It's an all in one furnace/hot water.
Old 03-02-2013, 06:55 PM   #21
Also, about the temperature settings. The hot water was set at 212 degrees when I first moved in. There were still no hot showers but they were slightly warmer than they are now. The temperature has been turned done to 180 as there were overheating issues in the upstairs and to conserve oil. I assume the previous owner was compensating for lukewarm showers as well.
Old 03-02-2013, 07:06 PM   #22
Rewards Points: 12
Wow! I believe the safe range is 120 for a water heater. I couldn't find anything on the 3100ST just 3100WT. Says it puts out 3 1/2 GPM of hot water.
Sounds like a pre-existing condition. I would rule out cold water crossover. After that I'm out of ideas short of calling in your boiler technician to see if the tankless is properly working.
Old 03-02-2013, 07:45 PM   #23
Well thank you for all your help. I think you're right about needing a technician at this point. I was told it needed to be at 180 for baseboard heating but I will look into that.
Old 03-02-2013, 08:08 PM   #24
Rewards Points: 12
You probably have two thermostats. One for the heating boiler which is the 180 degrees and a separate one for the tankless water heater. Not knowing the unit maybe there isn't a thermostat for the tankless.
Please post back when you get this resolved. I'd love to know the problem.
Old 03-03-2013, 12:08 PM   #25
No answer yet, but another piece to the puzzle is that the water pipe (coming out from the mixing valve) is hot when no one was using the hot water and the furnace was off. When the downstairs shower was turned on (it ran hot water for maybe 30 seconds before getting colder) the pipes went cold and stayed cold for several minutes after the shower was off before getting hot again.
Old 03-03-2013, 12:38 PM   #26
Rewards Points: 12
Just a guess. The mixing valve is bad or is not set correctly.
I'm making the assumption that there's no temperature control for the tankless so the mixing valve mixes cold water to bring the hot water temperature (180 degrees) to a safe level.
If there is a shutoff valve before the mixing valve, try closing it and see if it does anything to the hot water at the fixtures.
Old 03-03-2013, 04:32 PM   #27
Well the mixing valve is brand new- it was replaced in January. I'll look for a shut off valve.
Old 03-12-2013, 06:26 AM   #28
It looks like it's the hot water coils. They will either need to be replaced, but a separate hot water heater tank or replace the furnace.
Old 03-12-2013, 09:23 AM   #29
Rewards Points: 12
Bummer. If you're going to be in your house for a while, it probably makes sense to upgrade your 84% boiler to a high efficiency one.
No hot water in shower, but works elsewhere. Please help! neatfreak Plumbing 14 09-18-2012 12:38 PM
Low water pressure in shower Bluew126 Plumbing 5 08-28-2012 07:47 PM
Sewage smell from shower drain, trap has water, vent was snaked and was clear clearasmud Plumbing 1 04-24-2011 07:28 AM
Potential Water Issue in New Shower? cobrakai Kitchen & Bath Remodeling 4 02-12-2011 06:36 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 11:24 AM
