No Hot Water Pressure In Up Stairs Shower. Cold Is Fine. - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-09-2010, 04:09 PM   #1
No hot water pressure in up stairs shower. Cold is fine.
We have 3 showers in our house two of them work fine but the shower upstairs has no water pressure when you turn it on hot. I tried to up the water pressure valve and still no hot water it just drizzels? Help!?!?
my4boyz27 is offline   Reply With Quote
Old 09-09-2010, 04:31 PM   #2
Owner
LateralConcepts's Avatar
Is this a single handle shower valve? Probably need to replace the cartridge. If it's just the hot side of a double handle, pull the stem and flush it out. (either way, blocked with debris)
What do you mean by "tried to up the water pressure valve"? If you're talking about the PRV Pressure Reducing Valve, you'll need to make sure it's properly re-adjusted. Should be regulating pressure at absolutely no more than 80 PSI. 75 is ideal.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Intermittent Low Water Pressure Fox Plumbing 4 03-02-2010 07:04 AM
Preference for installing tub spout? dolvio Plumbing 7 02-11-2009 11:53 PM
no cold water pressure to 2nd story chellecalvin Plumbing 2 02-09-2009 12:38 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 11:24 AM
