Old 03-27-2010, 10:55 AM   #1
no hot water pressure in kitchen faucet
We just installed a new hot water heater, it sits in a room next to the bathroom, with the kitchen one room away. We have pressure in all faucets hot and cold, except the kitchen. We have pressure on the cold side, took all connections apart down to the shut off valve and checked pressure, it was good. When the hose is not connected to the under side of the hot faucet, and we turn on the hot water shut off, we only get a small stream coming out of the hose. We have checked under the house, no leaks. And suggestions?
lunchlady is offline   Reply With Quote
Old 03-29-2010, 12:49 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
You have a debris blockage in the hot water shut-off valve at that sink most likely.
Turn the water completely off to the water heater, dismantle the hot water valve, put a towel over it and have someone turn the water on very briefly to try to flush it out.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Kitchen sink hot water pressure weak n0c7 Plumbing 2 02-15-2010 12:40 AM
Kitchen Faucet + shower diverter: Need help xtrips Plumbing 1 02-14-2010 04:27 PM
Replaced kitchen faucet - now less hot water? sde Plumbing 5 05-26-2009 04:16 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
