No Hot Water Out Of My Kitchen Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-31-2010, 04:04 PM   #1
No hot water out of my kitchen faucet
Ok, the problem I have is with my kitchen faucet. It is a single lever Price Pfister. When I turn the hot water on, it comes out just a little warm.
I disconnected the hot water supply line from underneath the sink and no hot water comes out from the stop valve. The water pressure is ok. The hot water work well at every other faucet in the house.
In another tread, someone mention a water temperature regulator, but I have no idea how to find out if there is one installed here in my house. I don't think the hot water line is clogged or anything because the pressure is ok.
Any help would be greatly appreciated!
Thanks.
JTapia is offline   Reply With Quote
Old 12-31-2010, 04:28 PM   #2
HVAC / Plumbing
Have you ever had hot water here ? If the water line is connected to the hot water line you should have hot water out of the stop
kenmac is offline   Reply With Quote
Old 12-31-2010, 05:51 PM   #3
Rewards Points: 1,666
Does water come out of the hot water supply pipe and if it does, is it hot? If it comes out, but of little volume, make sure valve is fully open. Any other plumbing work done in the house recently? Is this pipe far from the water heater?
bob22 is online now   Reply With Quote
Old 12-31-2010, 09:08 PM   #4
Household Handyman
Rewards Points: 1,408
You disconnected the hot water supply line where? From the faucet set itself, or from the stop valve? IF you have the supply line disconnected from the stop valve, and the stop valve is one of those plastic 1/4 turn type, this may be your problem. These, IMO, are notorious for the handle spinning on the stem and the ball inside the valve body not turning. Unfortunately you will have to shut off the water supply to the entire home to remove this stop valve for inspection.
Old 12-31-2010, 09:09 PM   #5
Yes, I remember having hot water like a year ago.
Old 12-31-2010, 09:15 PM   #6
Yes, water comes out of the hot water supply pipe but it is not hot. I comes out at room temperature and just a little bit warm sometimes. It comes out at full volume. I replaced the water heater about a month ago but I had this problem even before. I bought this house about a year ago and it is about 6 years old. The faucet is a bit far from the water heater, but my shower is farther from the water heater and I get hot water in my shower.
Old 12-31-2010, 09:24 PM   #7
I disconnected it from the stop valve. But the stop valve is not one of those plastic ones. It is one of those silver metal ones.
Old 01-01-2011, 07:53 AM   #8
Makes no sense to me since shower gets hot water and is further away (and when it does; does the kitchen water still not get hot?) unless there is some mixing valve or some sort of crossover with cold water supply possibility and/or this piping is exposed to very cold temperatures somewhere and is taking the heat from the water to warm up, delaying hot water delivery.
Old 01-01-2011, 10:11 AM   #9
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,626
Ayuh,... Is hot water available At the stop valve,..??
If so, the faucet cartridge is stuck/ corroded/ plugged...
Bondo is online now   Reply With Quote
Old 01-01-2011, 12:00 PM   #10
Rewards Points: 1,536
That is, now that you disconnected the faucet lead from the shutoff (stop) valve, if you let the water run longer from the stop valve into a bucket below then does the water get hot eventually?
Old 01-01-2011, 04:25 PM   #11
You are right, it does not make sense at all and that's why i'm seeking help here in this forum. I've tried a lot of things and nothing seems to work.
Old 01-01-2011, 04:30 PM   #12
When i disconnected it, I only let it run for like 2 minutes. I guess I need to disconnect it again and let it run for 5-10 minutes to see if I get hot water.
Old 01-01-2011, 04:32 PM   #13
HVAC / Plumbing
If it's tied to the hot water side of the wh, it will have to get hot out of the stop valve sooner or later
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 11:31 AM
taste of chlorine in water from newly installed kitchen faucet ilyaz Plumbing 4 04-20-2010 03:14 PM
Replaced kitchen faucet - now less hot water? sde Plumbing 5 05-26-2009 03:16 AM
Installing Faucet with cold water only - How to cap off hot water inlet? jrterry1976 Plumbing 3 02-27-2009 07:27 AM
Help! hot water won't stop running despite faucet changes. nodak_luke Plumbing 4 12-14-2007 05:38 PM
