No Hot Water From A.O Smith GPSH/GPCR Gas Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-07-2012, 07:16 PM   #1
Exclamation
No Hot water from A.O Smith GPSH/GPCR Gas Water Heater
Folks,
I have a 6 yr old A.O. Smith GPSH/GPCR Power Vented Gas Water Heater.
This morning, I saw that there was no hot water running in my house, so, went downstairs to check the heater. The following LEDs were on:
1. First LED that has a label VAC -- It's green.
2. Third LED that has a triangular symbol -- Amber.
3. LED marked C -- Amber.
Looked up the manual, it says the Pressure switch remained open longer than 5 seconds after the combustion blower was energized.
Under the Solution section, found the following:
1. Pressure switch wiring incorrect.
2. Pressure switch tubing is not connected correctly
3. Air intake or exhaust obstructed.
I wonder what this means? Any thoughts / Suggestions on how to fix this?
sghatty is offline   Reply With Quote
Old 03-07-2012, 07:23 PM   #2
Rewards Points: 582
Originally Posted by sghatty View Post
Folks,
sinse unit has been in for awhile Iwould look at 3.. something in inlet air or out let exhaust
Tags
ao smith , water heater
ao smith water heater pilot light james-york Plumbing 0 04-05-2011 10:53 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
AO Smith GPSH water heater in System Lockout mode but resets itself gpatalin Plumbing 0 12-09-2010 09:09 AM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 10:33 AM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 10:36 AM
