-   -   No Hot water from A.O Smith GPSH/GPCR Gas Water Heater (http://www.diychatroom.com/f7/no-hot-water-o-smith-gpsh-gpcr-gas-water-heater-136319/)
sghatty 03-07-2012 08:16 PM
Folks,
I have a 6 yr old A.O. Smith GPSH/GPCR Power Vented Gas Water Heater.
This morning, I saw that there was no hot water running in my house, so, went downstairs to check the heater. The following LEDs were on:
1. First LED that has a label VAC -- It's green.
2. Third LED that has a triangular symbol -- Amber.
3. LED marked C -- Amber.
Looked up the manual, it says the Pressure switch remained open longer than 5 seconds after the combustion blower was energized.
Under the Solution section, found the following:
1. Pressure switch wiring incorrect.
2. Pressure switch tubing is not connected correctly
3. Air intake or exhaust obstructed.
I wonder what this means? Any thoughts / Suggestions on how to fix this?
ben's plumbing 03-07-2012 08:23 PM
Originally Posted by sghatty (Post 872962)
Folks,
sinse unit has been in for awhile Iwould look at 3.. something in inlet air or out let exhaust:yes::yes:
