No Hot Water At Kitchen Sink But Every Other Faucet Does.. - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-04-2012, 04:42 PM   #1
Post
No hot water at kitchen sink but every other faucet does..
Ok so I have hot hot water in both bathrooms however I do not at the kitchen sink.... We replaced the faucet and pipes under the sink thinking that may be the issue but clearly was not. We put the same type faucet in one handle controls both hot and cold.... plus a sprayer. Any ideas? Could the problem lie in the pipes in the basement?
thess is offline   Reply With Quote
Old 05-04-2012, 05:07 PM   #2
Rewards Points: 1,300
Most likely. Do you get cold water out of the hot side or no water at all?
danpik is offline   Reply With Quote
Old 05-04-2012, 10:02 PM   #3
Sounds like a valve is shut off in the basement. Is there a valve at the sink on the hot side? You could shut off the hot supply to the kitchen sink. Disconnect the hot supply then open the valve to check for water. Is it copper pipe?
sanec1 is offline   Reply With Quote
Kitchen sink takes too long for hot water. msaeger Plumbing 14 12-05-2011 11:11 PM
Kitchen faucet, low hot water pressure carlas Plumbing 2 12-02-2011 09:07 AM
no hot water kitchen faucet Vicky Sinz Plumbing 3 10-16-2010 07:46 PM
taste of chlorine in water from newly installed kitchen faucet ilyaz Plumbing 4 04-20-2010 03:14 PM
kitchen sink hot water acting funny jr2dr Plumbing 5 10-29-2008 07:56 PM
