No Hot Water In Kitchen Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-30-2009, 07:34 PM   #1
acb
Unhappy
no hot water in kitchen sink
any suggestions
acb is offline   Reply With Quote
Old 04-30-2009, 08:03 PM   #2
Oldie but Newbie
Oh, fer 's sake, don't make us play 20 questions.
Is there hot water elsewhere?
Did this just happen suddenly or did it come on gradually?
Any other work going on that might have caused this?
Have you tried turning on the supply spigot under the sink?
Do you have a single- or double-handled faucet? Does it feel different?
LookoutRanch is offline   Reply With Quote
Old 04-30-2009, 11:14 PM   #3
Maybe the shutoff is closed.
hayewe farm is offline   Reply With Quote
Old 05-01-2009, 01:36 AM   #4
Rewards Points: 562
faucet holes are pretty small. ANY good size grit can plug thm up,or a large size chunk of scale broke loose someplace,like in the water heater and traveled to smallest orifice and got stuck!!!FIRST thing is screw off the aerator and see what kind of stuff is stuck in there. Probably same crap only bigger plugging shutoff or faucet area. Take the supply line off before sink,have assistant turn water on while your catching it to flush pipe. No water comes out dig down further,water comes out there,blow back thru faucet with a good blast of air
4just1don is offline   Reply With Quote
Old 05-01-2009, 08:12 AM   #5
plumbing contractor
PLUMBINGITALL's Avatar
[quote=LookoutRanch;267798]Oh, fer 's sake, don't make us play 20 questions.
GIVE A LITTLE MORE INFO
PLUMBINGITALL is offline   Reply With Quote
Old 05-01-2009, 08:34 AM   #6
Since the space under sinks is usually used for storage, check the supply tubing for kinks caused by overstuffing. If it is not kinked, turn off the supply valve, disconnect the tubing and hold a rag over the valve opening and turn it on and off quickly. This will let you know if water is reaching the valve. Probably some trash in the faucet itself or a bad O-ring or cartridge.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 05-01-2009, 08:31 PM   #7
acb
Thanks alot !
Old 05-02-2009, 03:25 AM   #8
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
The OP really isnt very chatty, huh?
Thats like telling a mechanic over the phone...."hey, my car is making a funny sound"....then hanging up.
ooooookay
JDC is offline   Reply With Quote
Low water pressure in kitchen faucet after replacing water heater SusanonDaffodil Plumbing 8 01-27-2011 01:28 PM
Leaking kitchen sink drain pipe zasior Plumbing 10 01-11-2009 07:22 PM
Low hot water pressure on kitchen faucet Ultrarunner2017 Plumbing 7 12-19-2008 09:49 AM
Caulking around kitchen sink deeaa Remodeling 8 07-13-2008 03:12 PM
vent stack for kitchen sink Knucklez Plumbing 4 04-02-2008 06:49 PM
