No Hot Water Kitchen Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-15-2010, 06:29 PM   #1
no hot water kitchen faucet
Just moved into a new house a few weeks back, i told my husband that the kitchen sink had only warm or cold water not hot! He adjusted the water temp and it worked, i had hot water! Well 2 days later i have neither warm or hot water coming from that kitchen sink, only ice cold! He checked a few things but nothings worked! Could it be the faucet or is it the plumbing?? Thanks
Vicky Sinz is offline   Reply With Quote
Old 10-15-2010, 10:32 PM   #2
HVAC / Plumbing
Yes , It could be. Do you have hot water at the other fixtures ? Take the connector off the hot valve under the sink (where it connects to the fixture). Turn the valve on run some hot water in a bucket. If the water is hot . problem is in the fixture
kenmac is offline   Reply With Quote
Old 10-16-2010, 05:58 AM   #3
And make sure all shutoff valves are full open. Older washer type shutoff valves often have problems with washer disintegration, and the pieces will clog up at any stricture, like a faucet valve.
Old 10-16-2010, 07:46 PM   #4
Ok thanks Guys, my husband will be checking what u both said later tonight! We have hot running water every where but at the Kitchen sink, the house is over 30 years old so was not sure what it could be & why! Love this website & that it actually HELPS!
taste of chlorine in water from newly installed kitchen faucet ilyaz Plumbing 4 04-20-2010 03:14 PM
Replaced kitchen faucet - now less hot water? sde Plumbing 5 05-26-2009 03:16 AM
Installing Faucet with cold water only - How to cap off hot water inlet? jrterry1976 Plumbing 3 02-27-2009 07:27 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Help! hot water won't stop running despite faucet changes. nodak_luke Plumbing 4 12-14-2007 05:38 PM
