No Hot Water Flow - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-17-2011, 08:28 PM   #1
No hot water flow
What would cause an air bubble or something like that that would stop the water flow between the the hot water heater and all the hot water faucets in three bathrooms? They are in a row on one side of the house. It has happened about four times recently. After about an hour the water is flowing normally. It is summertime, and the house is air conditioned and is set to about 75 degrees.
Any ideas?
janetsr is offline   Reply With Quote
Old 09-18-2011, 09:19 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 608
Ayuh,... I guess I'd be lookin' at the heater, if it's the common connection between the system...
A Bubble can't stop the water flow, as it would be pushed to the faucets..
Old 09-18-2011, 12:20 PM   #3
Rewards Points: 1,442
Do you get hot water anywhere, such as in the kitchen?
How old is the house?
Old 09-18-2011, 04:23 PM   #4
AlbacoreShuffle's Avatar
How old is your home ?
It may be time for a re-pipe.
Try taking the hot supply line off a faucet and then spray it in a bucket .
This will tell you if the blockage is in the faucet or in the valve or plumbing below the floor.
AlbacoreShuffle is offline   Reply With Quote
Removing water flow restrictors Alvis Plumbing 9 03-25-2012 11:09 PM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 12:31 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Tub hot water does not Flow at all (details enclosed) lisaz Plumbing 7 12-17-2008 09:16 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
