No Hot Water Or Coming Out Of The Guest Bathroom Tub. - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-09-2011, 12:52 PM   #1
No hot water or coming out of the guest bathroom tub.
No hot water or pressure coming out of the guest bathroom tub.
My house was built in Dec. 2007, so fairly new...I live alone, so I never use the guest bathtub. I have had guests use it maybe 4-5 times ever. When I had guests the other day & they went to use it there was no pressure or hot water. I turned the lever all the way over to the hot side and no water came out at all...if you turn it about 3/4 of the way over it's just cold water and hardly any pressure. Any idea what is wrong?
mwallace1969 is offline   Reply With Quote
Old 12-09-2011, 01:15 PM   #2
Particles can get into water lines and clog valves which have small openings.
So perhaps a particle, small piece of plastic, or whatever was in the hot water line, then when the hot turned on for that valve, it tried to get out, but instead clogged the small opening.
You can "backflush" to fix that...
Turn off the hot water at the water heater.
At a nearby bathroom sink, disconnect the hot water line and run a line from the valve in the wall into a bucket.
Then turn on the hot and cold at the same time on the shower (middle position). Place your hand over the spout.
Then cold water will flow into that valve, then out the hot water side along with that particle. And will flow through the hot water line to that open hot water line under the sink and into the bucket!
Billy_Bob is offline   Reply With Quote
Old 12-09-2011, 01:29 PM   #3
OK - I will have to see if I can try that myself! I have no experience w/ stuff like this, however, your reply seems self explanatory...so let's cross our fingers I don't flub it up! haha Thanks - Melanie
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
Low/No Hot Water Pressure after changing Elements Onehipcat Plumbing 18 08-05-2010 09:16 AM
First time homeowner from MD - Water Leaking from Ceiling under bathroom j_cross Plumbing 2 02-26-2010 11:37 PM
Furnace troubles, where's the water coming from... Head Scratcher HVAC 10 03-23-2008 07:40 PM
No water coming from main water line in bathroom sassylaroo Plumbing 6 10-29-2007 05:34 AM
