No Hot Water On All Faucets - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-12-2013, 08:38 PM   #1
No hot water on all faucets
There is no hot water coming out of any faucet except both tub/showers have hot water. Copper piping through out the house and the tank is 20 years old (yes, I know it should be changed). Can the piping be flushed out or should I just replace the tank?
Duddy is offline   Reply With Quote
Old 02-12-2013, 08:42 PM   #2
Do you really want someone to answer that?
paintdrying is offline   Reply With Quote
The Following User Says Thank You to paintdrying For This Useful Post:
Duddy (02-12-2013)
Old 02-12-2013, 10:57 PM   #3
either someone turned a valve off or the aerators are clogged or the faucets are piped backwards and you need to turn it to the cold side.
Old 02-13-2013, 05:16 AM   #4
Rewards Points: 87
Duddy
I agree with DannyT although I'm not so sure about the aerators being clogged as the aerators would reduce the flow or diminish it altogether.
Are you getting water out of both hot and cold sides of the faucets? If you are getting hot water in the showers, run both faucets at once to check on whether the water lines are reversed. Also, check the cut off valves under the sink to make sure they are both open.
The house I just bought has 4 water heaters: 2 large and 2 small (I also have a small apartment on the 2nd floor). Are you sure there is not a 2nd water heater that may be turned off?
Hope this helps!
Fredericksburg, VA
momof2labs is offline   Reply With Quote
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 12:59 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
