#1 |
no hot water
hi ive just changed my tps on the bath and now have hot water for only acouple of seconds,i turned off the stop cock drained off exess water then changed taps before turning the stop cock back on water was running but cold form both taps i have a thermal store cylinder with the heating boiler down staires which i didnt turn off not sure if this made a difference.any ideas on wot the problem is cheers.
#2 |
the Musigician
no hot water
tps?
DM
[SIGPIC][/SIGPIC]Click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. to see some of my original magic tricks and trick boxes! |
#3 |
Man of many hats
no hot water
Man of many hats |
#4 |
no hot water
If water was drained from the water heater/boiler and it was electric, the elements might be fried; won't make cold water hot then (no one needs a hot water heater, right?).
#5 |
no hot water
I think he meant tempature adjusting valve meaning the shower valve,,,anti scald guard,,what ever you wanna call that today.
Think he has gunk in cartridges!! Last edited by 4just1don; 02-15-2009 at 01:41 AM. |
#6 |
the Musigician
no hot water
don, that was my first thought too, but not gunked, just not set to right temp. too low and it won't allow hot at all...
bob22, if one of the elements was fried (bottom?), it'd have more than a few seconds hot water. tps=temp/pressure...supply? supressor? DM
[SIGPIC][/SIGPIC]Click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. to see some of my original magic tricks and trick boxes! Last edited by DangerMouse; 02-15-2009 at 06:04 AM. |
#7 |
philplumb
no hot water
It could be the dip tube in the water heater. If the dip tube breaks off the cold water will enter at the top of the water heater instead of the bottom and quickly enter the hot water supply line...If this is the problem it is a fairly quick and easy fix.. It could also be your temperature limiter in the shower valve. Not knowing the manufacturer or type of valve limits any comments to this issue.
| Display Modes | |
| Low hot water pressure | crebive | Plumbing | 38 | 02-26-2013 01:26 AM |
| low hot water pressure | angus242 | Plumbing | 10 | 01-08-2009 12:41 PM |
| Water level in boiler system | Barefoot Brian | HVAC | 3 | 10-19-2006 02:11 PM |
