No Hot Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-17-2012, 02:28 PM   #1
No hot water
Just installed a new hot water heater on Saturday, and we are not getting hot water to any faucets and showers
raiderk is offline   Reply With Quote
Old 12-17-2012, 02:32 PM   #2
Rewards Points: 1,596
electric or gas?
Did you get any hot water out of it at all?
bob22 is offline   Reply With Quote
Old 12-17-2012, 02:33 PM   #3
Gas. we are getting some luke warm water
Old 12-17-2012, 02:44 PM   #4
Might want to try to make sure all basics are covered:
gas valve fully in on position (handle parallel to gas line); read manual for shutting unit off. Do so.
Then read manual for restarting heater. Pilot may be out etc...
Also, what temperature is thermostat set at? May be too low.
Just to check; no hot water from any house fixture?
Old 12-17-2012, 06:50 PM   #5
Rewards Points: 13,752
Is there no flow at all or is there plenty of flow and the waters just not getting hot.
Old 12-17-2012, 10:29 PM   #6
Rewards Points: 1,514
Did you install it yourself? Did you by any chance hook up the pipes backwards, namely the cold inlet pipe to the hot tank outlet and vice versa? Is the dip tube (should be down the cold water inlet) damaged or missing?
Advance the temperature knob. Do you observe the burner working properly as viewed through the little window at the bottom? You may need to remove the outer hatch cover, which snaps off easily, to see the window. (For a new heater, do not leave the knob in the "very hot" position for more than a few minutes.)
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
