Old 12-03-2012, 11:52 PM   #1
No hot water....?
Hi everyone! I'm new here and didn't get the chance to read very many posts so I hope this isn't a repeat question.....but......
The hot water in my kitchen sink hasn't ever been as hot as in the bathrooms. As of today though I have no hot water in my kitchen (sink, dishwasher) and adjoining laundry room (washing machine). Both of my bathrooms, which are on the far side of the house, have hot water. I checked the valves under the sink and they are both (hot and cold) on all the way.
I really don't want to call the nosy landlord unless I absolutely have to.....any ideas?
Thanks ahead of time
melissad52077 is offline   Reply With Quote
Old 12-04-2012, 12:21 AM   #2
call me E
TheEplumber's Avatar
No hot water....?
my first thought is you have a failed cartridge in your faucet. Is the faucet a single handle? Can you tell the brand? Do have any water flowing out the hot side?
Old 12-04-2012, 01:33 AM   #3
No hot water....?
The faucet is a single handle. No water is leaking above or below the sink. Couldnt find a brand name.
Thanks for responding!
Old 12-04-2012, 07:12 AM   #4
No hot water....?
You didn't give your location. As so many taps seem affected now, is a frozen pipe a possibility? As for your kitchen, and being a rental, I would also suspect a failed cartidge on an inexpensive tap.
daveb1 is offline   Reply With Quote
Old 12-04-2012, 07:24 AM   #5
No hot water....?
I live in GA so no possibility of a frozen pipe. The dishwasher is also affected so not sure that its just a problem with a faucet.
Old 12-04-2012, 12:34 PM   #6
Special User
No hot water....?
When you say you have no hot water, does that mean that
1. No water at all comes out
or
2. The water comes out cold
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 12-04-2012, 12:40 PM   #7
No hot water....?
The water comes out cold only.
Old 12-04-2012, 02:08 PM   #8
call me E
No hot water....?
I still think the cartridge in the faucet has failed. As a tenet you should inform the landlord. This is a maintenance issue not caused by you
Sent from my iPhone using DIY Forum
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (12-04-2012)
Old 12-04-2012, 03:13 PM   #9
No hot water....?
Couldn't I just replace the faucet? It couldn't be too hard to do could it?
Old 12-04-2012, 03:25 PM   #10
Special User
No hot water....?
Well, a kitchen faucet is usually pretty easy to replace with a crescent wrench and some plumbers putty. Depending on your faucet, sink, and cabinet design, you may need specialized tools... but they are seldom absolutely necessary in a kitchen.
However, this may violate you renter's agreement. And if there is a subsequent leak causing water damage, you may be liable for $1,000s in repairs. Plus it's like giving the landlord free money, that's probably the worst part!
Old 12-04-2012, 03:32 PM   #11
No hot water....?
Thanks for the advice. You are absolutely right. I never thought about the consequences of screwing something up.
Old 12-04-2012, 06:35 PM   #12
No hot water....?
you are not allowed to work on property that don't belong to you ..you could be sued if something happens.....Iam A landlord as well....call yours to have him fix the problem...ben sr
Old 12-06-2012, 06:25 PM   #13
No hot water....?
Figured out the problem. The house has another water heater (electric) in the basement that feeds the bathrooms. So I called the landlord over to light the pilot light on the other (gas) heater....ha ha. Its ok though because he didn't know either.
Old 12-06-2012, 06:31 PM   #14
Special User
No hot water....?
Wow... that's kind of odd.
Thanks for coming back and telling us the solution though... we hate to be left hanging.
Old 12-06-2012, 06:38 PM   #15
No hot water....?
We thought so too. He said someone must have put it in because the bathrooms are so far from the original one. Maybe it was taking too long for the water to get hot? Sounds a little spoiled but.....works for me!
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
water borehole question joeuser General Discussion 2 04-18-2010 11:33 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
