No Hot Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-04-2012, 02:08 PM   #1
Ok no hot water at all not even warm. Tested with multimeter and everything tested ok for ohms reading. Thermostat and element. Unless I tested wrong. My tester was on ohms setting and when I would place tester on screws it would shoot up to voltage amount than down to zeros and stay at zero. It did this for thermostat and element.
The fuses in panel box are fine I changed just to count it out. I had issues in the past of fuses heating up but seem to be fine now.
What could the problem be other than what I covered so far?
kgagnon7 is offline   Reply With Quote
Old 11-04-2012, 04:15 PM   #2
Rewards Points: 13,300
Did you first check to see if there was incoming power to the heater?
Trying to test for ohm with the power on is a good way to burn your meter up.
Old 11-04-2012, 04:22 PM   #3
No power both fuses were out and tested to make sure no power before testing ohms
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
