Old 08-13-2011, 10:26 PM   #1
no hot water
A few days ago, my hot water got much hotter than usual. Then it just stopped working at all. What's wrong?
Electic dual element, about 10 years old.
msowell28152 is offline   Reply With Quote
Old 08-14-2011, 12:29 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
no hot water
Sounds like a failed thermostat. Easy fix.
Turn off the water heater power breaker (should be 30 amp double breaker for most).
Remove the cover panels for the upper and lower tstats and expose tstats.
Take a photo of or make a sketch of the exact layout and number of screws on each tstat (I always replace both at the same time...they're inexpensive.)
Go to a store and get two that look exactly like the old ones (doesn't have to be same brand.)
Next, remove ONE WIRE AT A TIME from the old tstats and connect it to
the new in the exact same place. You cannot go wrong with this simple method. Tighten the screws securely. No fuss. No muss. No testing. Foolproof.
Should solve your problem.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
water borehole question joeuser General Discussion 2 04-18-2010 11:33 PM
Well Water snuggles2010 Plumbing 3 04-13-2010 02:36 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
